Hot press clamping time I need advice
8/6/21
Andre
I am currently gluing 11" x 36" x 1/2" panels. Maple wood and pva glue. I would like to know how to calculate the time needed to hot press. I was told by someone online to just do 1 panel at a time, but I'd like to do 10 panels which would be 11" x 36" x 5".
When my glue guy did the calculation he said a stack that size would take longer to hot press than cold press. It didnt make sense to me. Anyone offer better help?
8/6/21       #2: Hot press clamping time I need advi ...
I don't think you understand the concept of heated platen veneer pressing. A true hot press has platens heated to 60-100° C. Pressing times are around 4-10 minutes. Only the veneer and glueline adjacent to the platen will be heated so there's no benefit to stacking panels.
Pressing times are determined by temperature, thickness of the veneer, glue type etc.
If you are laying a heating blanket over a vacuum bag or clamped up panels, this is not hot pressing and will confuse anyone you ask for technical advice. If this is your setup, think about how long it would take for the heat of the blankets to penetrate into the center of the stack. I don't think it would be a benefit to put a heating blanket over a stack in summer - it will just cause differential curing and tempt you to pull the panels out before the central panels have cured.
Have patience.
8/7/21       #3: Hot press clamping time I need advi ...
andre
Sorry I am gluing a bunch of 1/15" veneer in stacks that total 0.5" per piece. How long of a heat press would that take? I understand the platens are heated by oil and pressure is applied. Im trying to see if it's possible to do multiple pieces rather than 1 at a time. I stack about 10 pieces in a cold press for over an hour. I was hoping a hot press could increase productivity. I will admit my novice level about heat presses but have been doing cold press for 16+ years
8/8/21       #4: Hot press clamping time I need advi ...
Thomas Gardiner
If this is an ongoing production project then you may want to do some testing of layups. I would suggest pressing a full stack of veneers in sample panels with your press temperature high. Remove a sample at time intervals of say ten minutes. Cut the sample in half and note the temperature in the center of the core. What time does your glue need at that temperature? You can graph the core temperature over time and be sure that you will have a full bond in the interior at the optimum time/temp in the press.
    • Better Vacuum Cups, Inc.
    • Texas Woodworking Festival
    • American Fabric Filter Co.
    • Denray Machine
    • Template Services
