Problems with Wilsonart Traceless laminate-- very brittle.
12/7/17
Matt
Has anyone else noticed great difficulty with Wilsonart "Traceless" line of laminate?
We are doing a job currently and are having much more difficulty with it than any other laminate I've used. It's easier to chip even than eggshell cabinet liner.
The main problem is stuff we lay up by hand. Our glue is solvent based contact adhesive. When trim routing it, even a brand new two-flute bearing bit leaves a small amount of chipout. A bullet bit is even worse (brand new).
The items we ordered laid up on 3/4" PB went through the CNC and edgebander just fine (bander has diamond premil), no chipout at all.
Lay it up by hand, pass over with trim router, you get chips. Small ones, but definitely noticeable.
It's also easier than normal to flake a corner exposing the black phenolic.
Any tips on this stuff, specifically?
1/14/19       #2: Problems with Wilsonart Traceless l ...
HALLIE
Hi Matt, we are getting a lot of chip out with this material as well. We’re you able to find any solutions?
10/1/19       #3: Problems with Wilsonart Traceless l ...
Matt Member
Have you tried a downward spiral or compression cutter?
7/23/20       #4: Problems with Wilsonart Traceless l ...
Nate
We have been machining this material for a couple months. We are using compressions cutters on our CNC routers and are getting 2 sheets per cutter before chipping. Our edgebander is 3 weeks old and are having problems with our diamond premill going dull while machining the edge. Has anyone found any good solutions?
12/27/23       #7: Problems with Wilsonart Traceless l ...
chad
Website: http://Uhurudesign.com
The grey trace less seems to be ever worse.
We put brand new cutters on the edge-bander premill and started chiping after 100' or so.
solution- move the cutting edge so its not cutting the same place for too long.
we move our cutters down after a few panels end the edge looks great for a little while.
If your cutting this stuff all day every day, you are going to spend tons on tooling!
12/27/23       #8: Problems with Wilsonart Traceless l ...
Matt Member
I am shocked that they are still selling this abysmal product. I understand the appeal for it, the matte look is nice, but it's easily the most terrible laminate product I've ever seen in my life. We've forbidden our designers from selling it.
    • American Vision Cabinets
    • Salice America Inc.
    • American Fabric Filter Co.
    • INNERGY
