Sawing and Drying
Subject:
Finally going to build a Solar kiln
3/24/14
Keith Newton
Due to limited space out on my parking lot here at the shop in LR AR. I need to make it portable to load from the North side.
I have just gotten a really nice heavy duty metal frame on big industrial casters, which is 16' long x 52" wide, and 24" high.
With this, I will be able to pull it over by the mill, then load straight into it as the lumber comes off. Then I'll roll it over closer to the wall over on the North side.
I'm wondering if I can use 2" or 3" foam board for my North wall, and rather than making and hinging them, have them lift out for loading.
Would the type board listed below be suitable?
Board
3/24/14       #2: Finally going to build a Solar kiln ...
Gene Wengert-WoodDoc
The big concern with such products is how they will perform when the temperature gets hot...I would think that you are probably OK for north wall door insulation, but I did not find any temperature limits.
In a kiln I built with north wall doors, I used bi-fold doors and barn hinges from a farm supply store. Obviously, sagging of the door when it is open is an issue, but your frame sounds perfect for this application.
3/25/14       #3: Finally going to build a Solar kiln ...
I built the original kiln in 1978 but it is no longer around. Today is called the Virginia Tech kiln. So, you can see a second generation kiln, made a bit fancier by Brian Bond at Va Tech at
sbio.vt.edu/about/extension/vtsolar_kiln/
3/26/14       #5: Finally going to build a Solar kiln ...
Keith Newton
Thanks Gene, I found this on a technical page. "It is not recommended for applications where sustained temperatures exceed 165 °F." So I'm glad I didn't find my mistake the hard way.
