Sawing and Drying
Subject:
Degradation of wood when frozen
5/29/14
Mark gingery Member
Here's one for the group. We fabricate what are know in the industry as Column Isolation blocks, used in large freezer warehouses. They isolate the steel column from the footing to prevent the freeze from traveling. The blocks are normally 6" thick and 14 x 14 inches square, edge laminated, kiln dried white oak. I have done research on mechanical properties of wood and I am comfortable with product doing it's designed job. My question to the group is these blocks need to last fifty plus years and they will constantly be frozen. One can find a lot information on heats effect on wood, but not much on freezing it. Would a constant frozen state help preserve the wood or not.
5/30/14       #3: Degradation of wood when frozen ...
Gene Wengert-Wood Doc
Unless the wood is over 28% MC, the water in the wood does not and cannot freeze. The reason is that the water is not a liquid when it is adsorbed in the cell wall. So, there are no properties in dry wood that are dramatically affected by temperatures under 32 F. If the blocks get wet, it is a different story.
