Sawing and Drying
Subject:
question around routing of electric cables over my Woodmizer LT-15 Electric
6/11/14
Bill  Member
I am pondering about how I am going to route my 50' 4 AWG/3C electric cable over my new Wood-Mizer Electric LT-15 with 5 bed sections to give me the ability to cut a 31 foot cant. When my saw head is in the middle of my bed section I do not want my electric cable to drag the gravel on the ground and wear out nor do I want the electric cable to be a bother to me sawing. Bear in mind I have to go 15.5' one way and then 15.5 feet the other. Also I have a 20 foot Steel I-Beam (4x8) running horizontal to my sawmill that I have a hoist to pick up large cants and transfer them over to my trailer to move the. My sawmill will sit in my 12 x 32 foot covered shed that only has has 8x8 timbers with those steel I beams running the 32 foot length so I will have clearance to put my 31 foot trees into. Any suggestions or pictures would be appreciated. I dont have it built yet but am everything is ready to go. Thanks Bill from TN
6/11/14       #2: question around routing of electric ...
Per-Olov Member
I would reccomend you to install a rail in the ceiling , along the saw bed. There are small "carriages" for such tasks. The cable can then be tied in round loops to the carriages. I think 8 loops, dimeter about 60-70 cm, would be enough in your case. This system is used for telfers so the right source to find the rails and carriages is the "hoist/lift companies. For my own log band saw I have just a 5 mm steel wire, tensioned over the saw, with the electrc cable hanging in loops fasten to rings on the steel wire.
The rail is better as there are less friction. (I have no powwer feed.)
Regards
P-O
6/11/14       #3: question around routing of electric ...
Tennessee Tim
Website: http://tsmfarms.com
I'm in agreement with Per-Olov. A friend of mine has his on a cable trolleyed by pulleys. as it stretches out it stretches like a slinky and the wire weight pulls itself back into loops upon return of saw. His loops hang high enough they're not dragging or touching the log while sawing.
What part of TN.
Have a Blessed evening,
Tim
6/12/14       #4: question around routing of electric ...
al
What size motor? I would like an electric sawmill myself. I would have to run a large wire from
house panel to a small sub panel. I am not sure you need a number 4 from sub panel to
sawmill if you have a similar situation.
6/12/14       #5: question around routing of electric ...
Bill  Member
Thanks Guys for the response. I made a mistake as my 20 foot steel I-Beam will be perpendicular not horizontal to my sawmill but your comments gave me some ideas. I know there is a way to do it and the piece about the weight of the cable automatically causing the rollers to resend back will be great. My mill is in Delano TN right on the Hiwassee River. I have 19 acres of large straight Southern Yellow Pine. I will be cutting up and making pavilions and homes on stilts with my work. The 4AWG wire is what Wood-Mizer recommended and my electric motor is a 1 phase 10 HP motor. The folks at Wood-Mizer have been great to work with. Glad I found this forum.
I will post some pics of my 32 x 46 sawmill shed when I get done. It will be interesting milling 4x8x31 rafters for my big pavilion. Thanks again. Bill
6/13/14       #6: question around routing of electric ...
Tennessee Tim
I definitely understand the long saw bed. I had mine custom built to do 24' 6" cut. I've only cut 4 beams that long though (it's a pain to load a log that large BUT has it's beauty). I had plans for a timber frame with GREAT rooms!!
Check my website, I have a timber frame sawshed.
Tim
6/13/14       #7: question around routing of electric ...
Bill  Member
Thanks Tim I did check out your website in middle TN. You do some beautiful work. Yep a 31 foot log is going to be a bear and will require some extra effort and thoughts. Where there is a will there is a way, right? This is my first sawmill but I have cut my teeth with an Alaska Chainsaw Mill with a Skiel MS 660. I still have a lot to learn about keeping mold off our SYP while it is drying. Learn from mistakes. Good thing I have a lot of trees.
