Sawing and Drying
Subject:
Sawing white oak or red oak for flooing
2/4/15
Ken Member
If you are making wide plank flooring, what thickness would you rough cut it off the log for drying, for red and white oak?
If you have a board that is dried in the rough to 1 1/8 to 1 1/4 inches for red oak or white oak from 18 to 25 inches wide, is it worth more to cut that in half and make 2 wide plank pieces of flooring, or to sell it as the original size in the rough? Also, who would buy it and what would the market be?
2/6/15       #3: Sawing white oak or red oak for flo ...
Steve
If you're making flooring you don't want to be using wide boards. Wood ALWAYS expands and contracts with humidity, -which is constantly changing. Check the wood shrinkage calculator and find out how much the width of a 9" wide board will change if the moisture content changes, say 3%. You'll have some pretty wide gaps between the boards, not to mention warping etc.
2/11/15       #5: Sawing white oak or red oak for flo ...
Ron
I made a 1700 sq ft. red oak floor for our new house. I used air dried , then dried in an enclosed trailer with a fan and dehumidifier. I used random sized boards. This was the most efficient use of the lumber, plus you can cut out all of the bad stuff and get number one flooring. I sized them to 2 1/2" (plus the tongue). I planed down to 7/8". The big challenge was getting them all the same width on the shaper. The fix for that was to make a fence opposite the cutter.
