Sawing and Drying
Subject:
sawing shorts on Wood-Mizer Lt40
3/12/15
Frederico B Moretz Member
I need help in building a jig to allow me to saw short material on my band saw mill for turning blanks. Thank you very much for any ideas.
Fred Moretz
3/14/15       #2: sawing shorts on Wood-Mizer Lt40 ...
Per-Olov Member
I have a board, 2" thick and 6" wide. The length is enough to be clamped by three of the log clamps in my saw. When I have to cut a short part of a log I fasten that to the board by wood screws. Whith a cordless screwdriver it is a quick thing to do. The board can now be named fixture or "adapter". The piece to be cut has to be located on the saw bed so you can support the left side by the vertical arms on your saw to take the cutting forces. (The cutting force from the blade is rather low, about 50 -100 pounds. With a sharp blade a lot less.)
I have cut a lot of short pieces of trees to blanks this way.
3/14/15       #3: sawing shorts on Wood-Mizer Lt40 ...
Thanks very much for the idea. It sounds like good advice. I will try it today as I have some 2' burls to saw into blanks. Thanks again.
Fred Moretz
