Sawing and Drying
Subject:
How to kill beetles that like to eat Southern Pine
6/10/15
woodisgood
Any updates on how to kill beetles that like to eat Southern Yellow Pine framing in a building that is not air conditioned or heated ?
Would putting a orbital sander on the framing kill the beetles by vibrating their bodies to pieces and killing them by stressing them ?
How about Boracare ?
Thanks for the knowledge you share
6/10/15       #2: How to kill beetles that like to ea ...
Gene Wengert-Wood Doc
You need to get them identified. Are they still active? Call your county extension office for help.
Beetles in green syp wood do not like dry wood. Dry wood insects are usually not a problem with syp. At this point, they may be deep inside the wood, so surface treatments will not work. In any case, some loss of strength can be occurring, so prompt attention is a good idea. Once identified, we will know the proper, effective treatment.
6/10/15       #3: How to kill beetles that like to ea ...
Jaycee Member
hmmm.... got me thinking if Diatomaceous-Earth would kill them... Its kills just bout any bug you can think of if they walk over it sand fleas, ticks, spiders,bed bugs ect... you name it... they sell it at home depot for about 10 bucks a bag its non toxic to humans but read up on it before you try it... Iam sure some naysayer will come along and say it wont work but for 10 bucks your not wasting much and you may kill a few spider or ants while trying it good luck regardless.
6/10/15       #4: How to kill beetles that like to ea ...
D LaHart Member
Bi Fen works on every thing.
just use common sense and follow label.
Don't handle lumber till its dry.
6/10/15       #5: How to kill beetles that like to ea ...
Gene Wengert-WoodDoc
We can poison the outside of the wood item to prevent new infestations...Unless it gets rained on and the treatment is
washed off.
The second issue is how to treat and kill insects that are already in the wood and away from the surface. We need more than a surface treatment.
6/10/15       #6: How to kill beetles that like to ea ...
Jaycee Member
Diatomaceous-Earth will kill anything with a exoskeleton its a fine power dust that would penetrate the pours of the wood its kills them via dehydration because it cuts the insect this is why I suggested it yes its a topical but may work in this case could not hurt to try at such a cheap cost also non toxic
6/11/15       #7: How to kill beetles that like to ea ...
Although red oak does have large pores, other species have small pores and the holes between the pores are even smaller, so we would not get any penetration of a fine powder.
