Sawing and Drying
Subject:
River Birch mill thickness prior to kiln dry
2/9/16
BR
Want to make a dining room table. No experience milling/kiln dry. Have River Birch in front yard and want to make table. Need opinion on how thick to mill lumber prior to kiln dry so table can be
1 1/8" - 1 1/2" once finished.
Thank you
2/11/16       #3: River Birch mill thickness prior to ...
Gene Wengert-WoodDoc
Shrinkage in drying to 6% MC is about 7.4% on the average. A few pieces will shrink as much as 8% or 0.12". So, the green size needs to be 1.62" so that the final size is 1.5", but most pieces will be thicker. Then you also need to add a planer allowance of no less than 0.06", and a bit more of the lumber is rougher than normal. Than add a little more for cupping warp. River birch does indeed cup more than many species, so 0.12" is none too much. Then because the mill will cut plus or minus a little bit, you need to add 0.05" or more. So, to achieve all pieces at 1.50" after drying and planing, the green average size, also called target size, needs to be 1.50+0.12+0.06+0.12+0.05 = 1.85"
Now, many mills will cut a little thinner, because this assumes that you want every piece thick enough (1.50" after kiln drying and planing), and it is expensive to be perfect. So, maybe 1.80” target is more reasonable. Note that if you were to buy kiln dried lumber, the assumption or industry practice is to have 1.50" or thicker prior to drying for 6/4. This means that at the mill you can forget about shrinkage, planer allowance, and cupping, so you only need a target of 1.55" or 1/16" over thickness. However, tradition says 3/32" (0.09") or even 1/8” (0.12) over thickness, but this was developed when sawmills used circle saws which needed more planing to be smooth and target setting was not accurately indicated on the mill (more plus and minus thicknesses). Today, surfaces are smoother because saws are better and oftentimes the setting on the mill is very accurate so lumber thickness varies only a small amount.
2/11/16       #4: River Birch mill thickness prior to ...
BR
Perfect, very helpful.
Thank you
Guy cutting tree down says he has a mill and can do job. Any pertinent questions I should ask?
2/12/16       #5: River Birch mill thickness prior to ...
Steve
Just some thoughts. I'm not familiar with River Birch at all.
If your table is going to be one piece you might want to consider it being at least 2" thick if not 2 1/2" thick. Thicker is more likely to resist cupping after assembly. Thicker is also more rustic!
Even in a glue up (two or more boards) thicker is more stable.
Ask the sawyer what his cutting tolerance is and add that to what ever thickness your request.
Be very particular with leveling the boards/slabs while they are drying. 1/4" out of level is 1/4" of wood that needs to be planed off to get a flat board/slab to make into a table.
And be sure to put some kind of finish on the bottom of the table so you don't have different seasonal moisture changes from top to bottom which will cause warpage
2/12/16       #6: River Birch mill thickness prior to ...
If stock wants to cup, thickness is not going to limit that. If you like Viking looking furniture you can go that thick, but I sure wouldn't want to move it into the house! Some to this heavy slab furniture being built has to take 6 people to move it through a doorway.
