Sawing and Drying
Subject:
Pre-dryer???
1/27/17
Haessly Hardwood Lumber Sales Member
Boss has got this idea about re-engineering our t-sheds we use for air drying. Installing fans along the outside of the sheds to force a constant air flow, and completely open on the other side. from my limited knowledge, i assume to expect an increase of surface checking before going into the kilns. He has no intentions on completely enclosing these t-sheds, therefore, no attempt to control humidity.
Is this actually a sensible method to reduce the air dry time? Species to be used in these pre-dryer systems are to include: Northern Red Oak, White oak, and Poplar.
if so, what should the airflow be, going through the lumber?
1/27/17       #2: Pre-dryer??? ...
Gene Wengert - Wood Doc
With oak, maybe ten feet per minute--almost zero--when the wood is above 35% MC. With yellow-poplar, hard ample, etc., 600 fpm.
You can get information about this in DRYING HARDWOOD LUMBER, which is in the archives here at WoodWeb. There is a chapter on fan sheds.
1/28/17       #3: Pre-dryer??? ...
Ample Supply
What is hard "ample"?
1/28/17       #4: Pre-dryer??? ...
Gene Wengert-WoodDoc
Oops! Hard maple
