Sawing and Drying
Subject:
homade dry kiln heat source
11/13/17
Dan Member
So I have built a temporary 12x5 kiln in half of my garage. I have a wood furnace that has a plenum and was wanting to make a run off of it to heat the kiln. What do you think? The heat produced is around 115 at the end of the vent runs when burning hot.
11/13/17       #2: homade dry kiln heat source ...
Gene Wengert-WoodDoc
A process that is called heated room drying is used for drying eastern red cedar to avoid driving off the aroma. The same is used for drying bending stock. It is also used for small quantities.
So, you should find it will work very well. Always watch the drying rate, as drying too fast or too slowly can be a quality issue for the lumber.
11/13/17       #3: homade dry kiln heat source ...
That's not hot enough to sterilize the wood. You're going to need 150 degrees after the wood is dry.
12/7/17       #5: homade dry kiln heat source ...
Dan Member
It drops the moisture kind of fast.. so there is a checking issue. I am going to run another load in it soon and change how i seal the end grain. Walnut dries real slow for some reason. Anyone know the reason?
12/12/17       #6: homade dry kiln heat source ...
What kind of kiln schedule are you using?
