Sawing and Drying
Subject:
resawing moulder blanks
1/27/18
Max Member
Hi all,
We mainly deal with reclaimed wood, and we have a Baker ABXX horizontal resaw. The machine features a stationary conveyor and an adjustable head, and we opted for the digital readout. Because our raw stock is reclaimed, there's always going to be some variation in dimension, even among material that's been batched according to rough size. A lot of the stuff we mill is around 2 1/4 - 2 3/4 thick. When we're milling moulder blanks (either 7/8 or 1" thick), we usually set the blade at 1/4" above the conveyor, and run our stock through a first pass, essentially sacrificing a small skin veneer in order to get a fairly flat surface to use to make the subsequent cuts, leaving us with two 7/8" or 1" blanks per raw piece. Would we be better off shaving off the top of the piece, rather than having the blade cut 1/4" off the bottom? I figure it's easier to leave the blade set to a consistent height, rather than constantly changing to adjust for the height of the raw stock. Any insight is much appreciated!
1/28/18       #2: resawing moulder blanks ...
Gene Wengert-WoodDoc
It seems to me that the question you are asking is "How do I get a flat reference surface?"
Your technique is ok unless the piece has severe variations
A jointer would also work.
You could also set the first cut at 7/8 + 1/4 (or 1 + 1/4) and then use a planer (knife planer or abrasive sander) to get the required thickness and flatten that surface as well.
