Sawing and Drying
Subject:
Staining on white oak lumber
1/25/23
Seth
In the recent years we have been having a growing problem with "banding" stain marks on our white oak lumber from our supplier. Typically they are dark lines about 1-1/2" wide and are spaced a few feet apart perpendicular to the board (see photo). These stains go through the entire board making the boards useless. This most recent batch of lumber has the banding marks but is yellow instead of the darker color (also see in photo). Any ideas on what is the cause? I'm thinking it must have something to do with drying or storage process. Any thoughts would be helpful because this is becoming expensive (and time consuming). Sometimes our suppliers will return the wood and sometimes they wont.
View higher quality, full size image (1088 X 1798)
1/25/23       #2: Staining on white oak lumber ...
This appears to be sticker stain. Here is an article explaining its cause.
https://woodweb.com/knowledge_base/Causes_and_cures_for_sticker_stain.html
1/26/23       #3: Staining on white oak lumber ...
Seth Member
Thank you, Tom. I will check that out!
1/30/23       #4: Staining on white oak lumber ...
Reject the boards back to the supplier. It often happens because the stickers are wet.
2/8/23       #5: Staining on white oak lumber ...
todd S peirce
That bits that they won't take it back for ruining suck good looking wood. It doesn't look like they kiln dry there stickers at all. The biggest problem is when they cut it then stack it before the kiln or to be air dried . If they use outside wet stickers that are not covered or just laid around the yard,like i have seen. This will cause the type of stain that goes that far into the wood. I would kindly explain to them what the cause can be and that it is a shame to waste so much nice wood per year. Might lead into a discount later but is nice to help out the local small guys. Hopefully you have a good day sir, Todd
3/4/23       #7: Staining on white oak lumber ...
George Member
Although the trapped wetness cause between the sticker and lumber is cited or implied, only one solution is offered to use dry stickers. I had problems with sticker stain, but not now.
My solution is to restack /re-sticker the lumber after the first day or two. Coming off the saw, the wood is the wettest on the surface. I use 3/4 by 3/4 square stickers. After a day or two, I restack the pile, but rotate the stickers 90 degrees to a new spot on the wood stack. This now exposes both the wet faces of the sticker and the corresponding wet spot on the wood to the air. The sticker dry sides are now on an area of the wood that is also dry to the touch from being previously exposed to the air. Furthermore, this new location should be planned as the final sticker location next to the ends of the boards, evenly spaced along the stack, etc.
If you think about the slotted stickers, they are doing the same thing by not trapping water under the stick - essentially venting the water away.
If you still have problems, rotate sticks again back to original sides after they have been air dried a bit...or grab a new set of stick for the restacking. It all depends on your situation, wood, and climate.
I do realize this is more work, but will save the valuable wood. You can incorporate it into your movement process. it is worth the investment for me.
George
    • Forestry.com
