Sawing and Drying
My first log I've cut with my homebade bandsaw mill.
2/7/14
Rod Hays
It has a few bugs that I need to work out but all and all I'm happy with the way it's working so far.
2/7/14       #2: My first log I've cut with my homeb ...
Dave Boyt  Member
Congratulations on your first log! I kept waiting for you to either throw a blade or saw into a clamp, but you did good. It will go a lot faster & more smoothly with a little experience.
2/7/14       #3: My first log I've cut with my homeb ...
Rod Hays
I did good I think. I didn't wreck,and the blade stayed on and the mill seems to work not to bad considering it was built outside with a few hand tools..
2/8/14       #4: My first log I've cut with my homeb ...
JS Member
Congrats on a huge accomplishment making lumber on a homebuilt saw! I'm going to recommend getting a guard system on the mill as you WILL break blades and they can leave those wheels in any direction at lethal speed! Safety first and have fun with your milling.
2/8/14       #5: My first log I've cut with my homeb ...
Sam
Awesome saw,at least put a fender/scatter shield on it for your own safety.
2/9/14       #6: My first log I've cut with my homeb ...
Dave Edgerton  Member
Nice job. Would be nice if you could attach a winch or something like that to pull it through the log, or even a crank. I have a nice 20" dia ash log sitting in my driveway right now that needs a machine like that.
2/9/14       #7: My first log I've cut with my homeb ...
Rod Hays
Okay,today I am planning on putting on some blade guards. Good idea about having something pull the carriage. Maybe I'll try a winch
2/12/14       #8: My first log I've cut with my homeb ...
stan Member
looks great. what did you do with your turner mill you had.im still using mine I have had for 14 years.
2/12/14       #9: My first log I've cut with my homeb ...
Rod Hays
I sold it back in 2006 when I sold my place. The people wanted the sawmill also.
2/12/14       #10: My first log I've cut with my homeb ...
Rod Hays
My mill is kind of like the Turner I had but with the capabilities lacking from it.
2/17/14       #11: My first log I've cut with my homeb ...
Rich
It looks a little unsteady on it's legs. Are you not running on a v track? I didn't watch the entire video, so apologize if you show the tracking. I'd also like to see that adjustable guide a lot closer to the log if it were mine. Nice job though, you'll have a blast.
2/21/14       #12: My first log I've cut with my homeb ...
Rod Hays
Rich,it does look like its unsteady some what. It has v wheels. I have added saw guards and it seems to help with less unsteadness now. I plan on adding power feed pulling from both sides which I believe will cure the unsteady problem. Here is my latest video of the sawmill.
Latest video
