Sawing and Drying
woodmizer 3500 sawmill
3/4/14
vance Member
Has anybody else had problems with the setworks on the 3500 not being able to find its set point. woodmizer keeps blaming the cable and transducer which I have already checked out. Can't get a electrical engineer there to return my phone call even though I bought it new in 2011.
3/4/14       #2: woodmizer 3500 sawmill ...
Nick Holeman
Have you replaced the cable or transducer? They will cause it not to find its spot if either one is bad. Sometimes you physically can't see anything wrong with either of them, but they are still bad. Also it could be your electric brake. Sometimes dust gets in there and doesn't allow it to make good contact and it will bounce up and down and not find it's place for a little bit. Is there any message showing up on the screen, like failed to reach target?
3/9/14       #3: woodmizer 3500 sawmill ...
mike
very rare to hear of a WM customer support problem,,,, call them and explain your situation and frustration,,,,, they will take care of you
4/2/14       #4: woodmizer 3500 sawmill ...
vance
Have put on multiple transducers ,cables and plc. cards and problem always comes back, sorry it took so long to respond been gone and busy.
