Sawing and Drying
Cobalt blades coming soon
5/12/14
Rod Hays
Figure I'll try out these blades and see how they cut and last on staying sharp. Here is a video of how they weld the Cobalt to the blade.
https://www.youtube.com/watch?v=nHxfKx_vaic
5/14/14       #2: Cobalt blades coming soon ...
Dave Boyt  Member
I use them when I anticipate wire or nails in the log, but they seem to cut rougher than steel blades. I cut through more than 50 strands of wire slabbing out this walnut before a 3/8" bolt destroyed the blade. One slab paid for the blade, though, so it was all good. It is like having metal inlay!
View higher quality, full size image (2560 X 1920)
5/14/14       #3: Cobalt blades coming soon ...
Rod Hays
I figured if they say is ture that the last 7 times longer,and I figure the cost 3 times more then the other blades,it is a no brainer they are the most cost effective on overhead cost of blades.
5/17/14       #4: Cobalt blades coming soon ...
Gene Wengert-Wood Doc
What is the difference between cobalt and carbide? Carbide does have lots of cobalt. It is brittle. Stellite is a different formula of materials but has cobalt also and it is not as brittle.
5/17/14       #5: Cobalt blades coming soon ...
Carbide is made of tungsten carbide with a cobalt binder. The amount of cobalt varies from 1% to 30%, with 5% to 15% being common. It is my understanding that cobalt alone , say 90% cobalt, cannot be used. So, I do believe that we have had "cobalt" saws for over 100 years, but we call them carbide or Stellite. The video looks like carbide tipping to me.
Is the supplier playing with words when selling a saw they say is cobalt? Is it really carbide? Do they have this available for small saws? Can you give a link to the technical info about the material they are using and it's composition?
Many saw shops do have carbide tipping facilities. This re-tipping is often done with circle saws. Note that side dressing is important for carbide so that the saw cuts straight and does not wander.
5/17/14       #6: Cobalt blades coming soon ...
Rod Hays
Gene,here is about all I could find
Saw Blades
5/17/14       #7: Cobalt blades coming soon ...
Rod Hays
And this is the blade they say is Cobalt rich, high-speed steel tooth tips. Doesn't say how much Cobalt though.
Lenox Blades
5/17/14       #8: Cobalt blades coming soon ...
Rod Hays
Here is what the blade looks like.
View higher quality, full size image (4128 X 2322)
5/17/14       #9: Cobalt blades coming soon ...
Rod Hays
They have a blade they say is carbide tipped. They cost about double the price of the cobalt blades.
Lenox Blades
5/17/14       #10: Cobalt blades coming soon ...
Gene Wengert-WoodDoc
Stellite alloy is a range of cobalt-chromium alloys designed for wear resistance. It may also contain tungsten or molybdenum and a small but important amount of carbon.
Carbide also has lots of cobalt.
So, I think cobalt is available and has been in blades for decades. Is the company in the video doing something different?
5/17/14       #11: Cobalt blades coming soon ...
Rod Hays
I'm not sure if they are doing anything different. I just never knew how they welded the metal to the blade. In the video they make it look real simple as far as the welding goes. I was thinking the process was brazing on a bit,or something along those lines. The way they are doing it is just using round bar stock and spot welding it to the band blade and using an angle grinder as a cut off tool. Then it must go to a grinding process. It says they are welding stellite. Here is what they wrote
''The model SUK- 92 is specially designed for welding stellite ® drops on the tip of the cutting teeth of the band saw. Stellite ® tip is welded by current from a tooth. The amount of electrical current required for the welding depends on the thickness of the sheet and the diameter of the droplet of stellite ®. Gout welded stellite ® is automatically cut off by an engine mounted on the machine.''
