Sawing and Drying
Flooring installation in the Caribbean
2/3/15
Ken Member
Can you install solid ¾ inch wide plank flooring in the Caribbean on the 1st and 2nd floors of a concrete-built house?
Would treated lumber have to be used as a sleeper for red or white oak or maple wide plank flooring?
Because of the vapor barrier, could one use untreated Douglas fir with wide plank flooring over it, or on another note, put epoxy adhesive down directly to the concrete?
Does anyone have any knowledge of this installation in the Caribbean or for tropical environments (Not in South America, only the upper part of the Caribbean)?
2/4/15       #2: RE: Flooring installation in the Ca ...
Gene Wengert-Wood Doc
I have worked in three countries in that region. You must consider termites...flying termites. Therefore, use a highly termite resistant wood.
