Sawing and Drying
width of irregularly-shaped lumber for BF calculation
2/26/15
SR Member
What is the correct way to measure the width of an oddly-shaped board, as a basis for board-foot calculations? See attached photo.
I grant that much of the time it's relatively obvious, but sometimes, as in the case of the board on the right in the photo, which has a distinct curving pattern, it's not so obvious. If you go by the max largest piece that can be straight-lined, the curve "shrinks" this piece. But if you disregard the hook to the right at the near end, a wider board can be straight-lined.
The purpose of this is that I'd like to sell some of my surplus lumber and I want to be fair in my calculation method. I don't normally sell lumber and I generally trust my supplier's BF calculations as they are reputable firms, so I don't have experience with the finer points of the rules. I think I'm reasonably clear on the BF rules once WxLxT are known, it's just this technical point about calculating W that I'm not sure about.
View higher quality, full size image (720 X 1280)
2/26/15       #3: width of irregularly-shaped lumber ...
Dale Lenz
Website: http://www.beautifulwoodworks.com
Think, I'd sell by the piece. not BF...my 2¢
2/27/15       #4: width of irregularly-shaped lumber ...
Tennessee Tim
I normally sell by the slab due to each has different characteristics that change the value "per board foot".....BUT when it is necessary for customer specs to do B.F. and I've seen this as a common standard with live edge is measure from the wide side...IF they're fairly consistant in change we'll measure 3 spots (ex both ends and center and divide by 3 = average W) ...on extreme changing as yours shows I measure every 1 ft including starting end and divide accordingly...this is more accurate. DON'T forget the thickness and length in calculations. Yes they pay for the taper loss OR as I look at it the pay for the beautiful edge!!!
Nice slabs!!
2/27/15       #5: width of irregularly-shaped lumber ...
SR Member
Thanks! That answers my question.
2/28/15       #6: width of irregularly-shaped lumber ...
Gene Wengert-WoodDoc
I also would sell by the piece and not the footage.
From a technical point of view, the NHLA Rules require that a piece of lumber be "well manufactured" which this slab is not...that is, it is not a piece of lumber, but is an unedged slab. So, the standard rules do not apply.
You could lay out a piece of lumber with some wane that you could make from this crooked piece and then say something like "potential of making xx BF of lumber."
Because lumber is assumed to have parallel sides most of the time, if there is taper to the piece, then the width is measured at a spot 1/3 the length from the narrow end rather than using an average width. This "penalty" is a good compromise solution.
For pieces with wane, the width does include the wane.
