Sawing and Drying
severe checking in air-dried white oak
4/3/15
Rick U. Member
I seem to be having alot of checking with my air dried white oak. We've taken several measures to try to improve the quality of our lumber, but this white oak is relentless. The white oak comes fresh off the saw, end-coated with a heavy wax compound, then stacked on breeze-dry sticks and set under a T-shed to air dry, all in the same day. In less than a month, 80% or more is severely checked. lumber is cut with a ban saw type head rig & re-saw, blades changed mid-day, daily... any thoughts or suggestions would be greatly appreciated.
4/3/15       #2: severe checking in air-dried white ...
Don Lewis
If it then goes in a kiln, why not put it in the kiln sooner. Air drying isn't simple. I assume you've read the Gene's material on air drying and have the lumber protected from the sun and rain and excessive wind. Where you are makes a big difference.
4/3/15       #3: severe checking in air-dried white ...
Gene Wengert-WoodDoc
Checking results from drying too fast, which means the humidity is too low, air flow too high especially when humidity is low and / or temperature too high.
For green oak in a shed, we often suggest using Shade Dri cloth to slow air and Increase humidity
5/21/15       #4: severe checking in air-dried white ...
Cody Colston Member
That's the inherent problem with air drying...little to no control over the drying rate.
With a hard-to-dry species like white oak, one dry, windy day can give the results you are seeing.
