Sawing and Drying
Specs for Live Sawn or European cut Flooring Lumber
5/10/15
Joe Member
Hi There! I'm hoping to have a couple local sawmills cut white oak logs into lumber that i will use in the manufacture of European cut flooring. The lumber will be character filled, and will include the pith, within certain limitations. There will be two types of boards in this lumber, those that contain the pith, and those that contain a cathedral or wider grain pattern towards the center, which are flanked by tight grain on both edges.
Has anyone ordered this type lumber, and if so, what specifications did you give the mill in your cutting order? Thanks!
