Sawing and Drying
mc of core/shell and equilizing
6/19/15
woodlearner Member
according to kiln dryers operation manual the instructions for equalizing say to start equalizing when mc is 2% below target.My question is lets say your sample is at 5% and you cut a core and shell and find that the shell has a mc of 3% and the core has a mc of 9%. Should this be of concern? Should I wait for the core to drop lower before equalizing?
6/20/15       #2: mc of core/shell and equilizing ...
Gene Wengert-Wood Doc
I assume that you are drying hardwoods. I suggest that you use DRYING HARDWOOD LUMBER for your instructions.
In the DKOM, the maximum depression is 50 F which gives 3.3% EMC. So, the shell should never be as dry as you indicate. In DRYING HARDWOOD LUMBER, however, the maximum depression is 45 F which will give you closer to 4% EMC. I like 40 F depression even more. This is in the main schedule.
Assuming your final MC target is 7.0% MC, then you would start equalizing when the driest sample reaches 5.0% MC average for the whole piece and set in 5.0% EMC. This will stop the shell from drying under 5.0% MC on all but a few of,the driest pieces. The core will continue to dry.
You continue until the wettest sample is at the desired target...likely 7.0% MC for most people. So, now all pieces are between 7.0% MC and 5.0% MC. The core of,the wetteriece if still a bit high will dry a little bit more in storage, if needed.
Ok?
6/20/15       #3: mc of core/shell and equilizing ...
woodlearner
OK. So the core and the shell will equalize during the final? And will continue to equalize after coming out of the kiln? Or is the moisture locked, in the core or in the shell?
6/20/15       #4: mc of core/shell and equilizing ...
It will continue to equalize, but a one percent difference is the best in most cases.
