Sawing and Drying
Can I dry wood too much
8/11/15
Brock
I recently finished building a solar kiln and have my first load in. How important is it that the wood be removed as soon as it reaches the moisture content I want? (7-8%)
Or, can it be damaged if I leave it in the kiln several weeks after it is done drying? Would turning off the fans and closing vents keep the moisture content relatively stable for a few weeks once its dried?
I'm not in a huge hurry to use the wood (cherry), but don't really want to put it back under a shed and have it gain the moisture back.
I really enjoy reading this forum and appreciate all the years of knowledge you all bring.
Thanks!
8/12/15       #2: Can I dry wood too much ...
Gene Wengert-Wood Doc
Probably little chance of over-drying, especially if you do not run the fans after the wood is dry. You can also cover the collector to stop drying.
8/29/15       #3: Can I dry wood too much ...
joel
please explain why you recamend turning the fans off. i was under the impression that fan speed/ air velocity had little affect on drying under the fsp/30%
8/31/15       #4: Can I dry wood too much ...
When the fans are off, the hot air is not pushed into the load of lumber, so the wood MC remains fairly constant.
