Sawing and Drying
Wide Band Mill
9/26/15
Fred Clark Member
Website: http://www.baraboowoodworks.com
Has anyone had experience with a light, wide-band mill like the Hudson Oscar 52"? If you have, what quality of cut, consistency, rate of production have you achieved? Would you buy one again? We're needing a machine for daily production of wide slabs and looking for a step above chainsaw mills for productivity. Thanks in advance for any wisdom you can share!
9/26/15       #2: Wide Band Mill ...
Per-Olov Member
I have experience from log band saws with blade with of 27 mm up to 40 mm, we mostly use 1,5" = 38 mm. It is blades of ordinary type, bimetal, as have set. We are very happy with the performance, its far better than chain saw. I have a friend, he use 38 mm blades with teeth of stellite. Every teeth has the same with on the tooth tipp. There are no need to set. The blades is more expensive but it has loong life and the cut surface is like planed. You can grind it like HSS. His boards dimension has a variation less than 0,2 mm. I would say you do not need to look for wider blades.
9/26/15       #3: Wide Band Mill ...
Fred Clark Member
Thanks Per-Olov on the blades. 1.5" blades seems like the standard for these. We're mainly wondering about cutting performance for that size blade with a 52" throat. Is there more blade dive or thick and thin with that wide a throat - and that much potential blade deflection with a 52" throat? We've heard you need to change blades after every 2-3 cuts. That's Ok as long as we can count on getting 2-3 good cuts with a sharp blade and good settings. Thanks!
9/26/15       #4: Wide Band Mill ...
rod hays
I built a light wide band mill. I'm using an 1 1/2'' blade in the video below.It was my first was the time I ever cut a big log on the mill. I would of cut it faster if I would of saw the handle hitting the end of the log. I can only cut up to 38'', I was going to make it wider,but the band head is 7' wide and I didn't want to go any wider. So I believe the Hudson Oscar 52 would do the job.
YouTube video
9/27/15       #5: Wide Band Mill ...
Per-Olov Member
Fred, I have to say I don't know how 38 mm blades would work for 52" throat. Our saws has just about 35" throat.
To be successful to cut so wide slabs you would look for a saw as also can cut deep in the log. It is convinient to be able to perform many cut with the slabs still laying on the log. Many saws has a limitation as the blade tension system is located so low, in line with the wheel bearings.
I do know it is important to keep the blades sharp and grinded to the best hook angle for that kind of wood you are going to cut.
9/27/15       #6: Wide Band Mill ...
Gene Wengert-Wood Doc
A narrow band will bend front to back to relieve some cutting stress, so it tends to cut fairly straight. The wider bands, with high stress, can only bend side to side, so they might not cut as straight in some situations.
10/15/15       #7: Wide Band Mill ...
Dave Boyt  Member
What is the range of widths you need to saw? Is it the productivity or wide kerf (or both) that you dislike about the chain saw mills? I've been impressed by the slabber attachments of the Peterson & Lucas swing blade mills. I believe they go to 6' wide. Both mills also have planer attachments.
