Sawing and Drying
Bandsaw Blade Re-Sharpening
10/19/15
Tommy
When re-sharpening a bandsaw blade with the Cook “Cat Claw” or any other re-sharpening machine on the market, does the cam have to be changed to adjust for blades with a 1-inch tooth spacing to ones with 7/8 inch tooth spacing?
In other words, if the tooth spacing of a band blade changes, is there a setting or adjustment that can be made to these automatic sharpening machines to accommodate the changes in distance and depth of the gullet, to sharpen the teeth properly?
Please let me know.
10/20/15       #2: Bandsaw Blade Re-Sharpening ...
Per-Olov Member
Tommy,
I have experiences from some grinders, but not the Cook's. In all of mine it has been possible to adjust the blade feed system for different tooth space. There are two types of wheel for such machines, one "flat disc ceramic type" and a "diamond type wheel". Function for the "disk wheel": When the blade is feeded forward to next position, the wheel, in the same moment, grinds the gullet and the tooth back. The wheel up / down movement is controlled by the curve. Those two movements, creates the shape of the gullet. You can adjust the machine to an other tooth space .
For the diamond wheel: Because the wheel it self, is formed to give the entire gullet its shape, You have also to change the wheel to be able to resharp a blade with a diffeent tooth space.
10/20/15       #3: Bandsaw Blade Re-Sharpening ...
Ricky
On my sharpener you would have to change cam on different spacing. I would think so on the cat claw also but never seen one.
10/26/15       #4: Bandsaw Blade Re-Sharpening ...
Brian Rhoad Member
The Dinasaw sharpeners will sharpen any tooth profile and spacing without changing cams.
http://www.dinasaw.com.au/
12/14/15       #5: Bandsaw Blade Re-Sharpening ...
Robert Member
Website: http://timeless.house
Tommy how did you do this finally? Have the concern, and would like some tips.
