Sawing and Drying
Separating Lumber to sell
11/28/15
Richard
I have a stack of walnut lumber that was cut 4 1/2 years ago. It is stacked on a concrete floor in my barn and the boards are stickered. My question is how to go about separating the wood to sell. Do I just separate into lots to be sold as is, or try to put like grades together. Any help is appreciated.
11/29/15       #2: Separating Lumber to sell ...
wurthless
Well you could get a book on hardwood grading and learn to separate them by grade. Or use your own grading scale, using common sense or woodworking knowledge you may have. One way our another,,,, get more money for the better, clearer boards,,,,
11/30/15       #3: Separating Lumber to sell ...
Richard
Thanks for the reply. I was thinking of selling a set number of boards for x dollars and just mixing the grades in each packet of boards. Needless to say every one is going to want the best boards leaving the lesser grades. Im not sure if this is the way to do it or not.
11/30/15       #4: Separating Lumber to sell ...
Jim Member
My suggestion is to determine how many board feet is the the best wood. Next step is to determine how much money you want for the whole lot.
Divide the total money number by the best wood board feet. That is the price per board foot of the the best wood. Lower the pricing on the lesser grades. If they only pick the best you will get all of the money you were expecting. If you sell some of the lower grades, bonus money.
11/30/15       #5: Separating Lumber to sell ...
Gene Wengert-WoodDoc
When all the lumber is in one lot without sorting, it is called "mill run." You are close to that, so if each pile was essentially the same, you might use the name.
12/1/15       #6: Separating Lumber to sell ...
Gene Wengert-Wood Doc
With just a few logs, if each log, or even several logs together, are sawn and all the lumber sold in one lot, this is called "log run." Same idea as mill run, but smaller volumes.
12/1/15       #7: Separating Lumber to sell ...
Richard
Good info. Thanks to everyone.
