Sawing and Drying
Wood-mizer advice
4/6/16
Will Member
Can anyone give me insight on a Wood-Mizer LT15GO vs LT28? Obviously there is a cost difference but what about functionality or durability. I'll be sawing for myself and on a very limited custom basis.
4/18/16       #4: Wood-mizer advice ...
Dave Boyt  Member
Think about the size of logs you'll be milling. The 28 has more capacity. It is also twice the weight of the 15, which would indicate it is more robust, plus it uses the cantilever head they have on their bigger saws, and has more options. While you're looking, why not get info on other mills that sponsor WoodWeb? There is a good selection of manual band sawmills out there. Whatever you decide, go with the most powerful engine available-- you won't regret it.
6/4/16       #5: Wood-mizer advice ...
Steve N
If I was buying a push along mill it would be a EZ Boardwalk with the angled blade that pushed way easier. I run A TK hydraulic mill so no bias Steve
