Sawing and Drying
How about a WIND POWERED mill!
6/2/16
Keith Newton
I just stumbled onto this youtube today, and found it very interesting. Twould be nice to be off the grid, and no other fuel cost.
Near the end, he states that soaking in the mill pond for a year will eliminate the tendency to twist. You can see some spiral grain in the log out on the ramp, which would give a tendency toward twisted lumber. But I don't recall ever hearing that soaking would take that away. What say ye DR. Wengert?
https://www.youtube.com/watch?v=Q6FxG3ll-lw
6/3/16       #2: How about a WIND POWERED mill! ...
Leonard
That is interesting, if extremely antiquated and inefficient technology. Notice how the sawing slows down when the wind slows down.
Completely useless except as a curiosity and tourist trap.
And that log, no matter how long you soak it, will always be twisted.
6/4/16       #3: How about a WIND POWERED mill! ...
mark
Keith,
Thanks for posting this video, it serves to remind us where we have come from.
I have a book entitled "Woodworking Machinery its Progress and Construction 1800-1880" by M. Powis Bale which was written in 1880. The book devotes 2 chapters to reciprocating ripsaws which at the time were known as timber and frame deals. This style of saw has been referred to as far back as the 14th century, so have been around for a very long time. Attached is a drawing from the book of a cast iron version of the saw that can be powered by steam or water.
I would imagine that with the current knowledge in alternative forms of energy such as wind power that an efficient and economical version of a wind powered log saw is feasible.
Timber_and_deal_frame_circa_1878_2.pdf
6/5/16       #4: How about a WIND POWERED mill! ...
Gene Wengert-WoodDoc
Wind mills have been around for centuries need. They are a source of mechanical power, which can be used for many operations, including making electricity, grinding grain and sawing lumber.
Frame saws have been popular for many years, mostly using water power, but getting power from moving water or moving air is similar. Once converted to mechanical energy at the spinning wheel or turning blades, the rest is identical. Obviously, their production rate of about 1 mm per second or two even with a sash gang saw is very slow. It is much faster than a pit saw indeed.
With respect to soaking the logs, is this salt water? If so, we do know that salt has a big effect on drying, including checking and warp. In fact, sailing ship pieces of wood were often soaked to prevent cracking. In WW II, Mortons Salt had a process called Morton Cure that stabilized wood, but they had many lawsuits as the salt encouraged corrosion of metal. So, salt soaked wood needs to use wooden fasteners or non-corrosive metal. Of course, sugar has nothing to do with stress. In fact, soaking a green log that is already full of water has little effect, unless there are bacteria in the water.
6/6/16       #5: How about a WIND POWERED mill! ...
Keith Newton
Thanks Gene for the response. I didn't expect there to be any effect from soaking of the logs, for the same reason you stated.
I was wondering though, about this,"we do know that salt has a big effect on drying, including checking and warp."
Would that be due to the salt drawing moisture from the air, keeping the MC higher, or is there some other stabilizing affect?
6/7/16       #6: How about a WIND POWERED mill! ...
I am not enough of a chemist to describe the effect in detail, but I believe it involves bulking, plus cell wall and EMC changes.
