Sawing and Drying
Rough Sawn
4/25/18
MillworkDave Member
Anyone know any tips or tricks on replicating a rough sawn texture on beam and T&G? Not having any luck with a wire brush at all.
Thanks in advance
4/26/18       #2: Rough Sawn ...
Keith Newton
I'm not sure your wanting to make your saw cut rougher than it cuts now, or just roughing up bought lumber. I suspect the second, and even though I haven't tried this, you might bend about 8 - 10 teeth on your bandsaw blade out more so the set is off from the rest, then feed it through again just skimming with those teeth.
The number of teeth bent out will depend on the feed rate, so start out with less, then bend more as needed.
Of course, if your trying to match the texture of the original saw blade cut from the log, the wood would have been wet, and now it may be dry, so the properties would have toughened, so it may not tear out the same.
4/26/18       #3: Rough Sawn ...
Dave Boyt  Member
Website: http://www.pottershophollow.com
I had a customer complain that my wood was too smooth-- he wanted a non-skid floor for a stock trailer. The bent-tooth technique worked great. For "antique" furniture, people seem to like the curved marks left by a circle mill. Still looking for a way to simulate that, possibly a router at an angle so one side of the bit digs in, and put it on a jig to make a curve.
4/30/18       #4: Rough Sawn ...
Gene Wengert-WoodDoc
3M makes a product called brushalon that can be used to abrade a surface.
4/30/18       #5: Rough Sawn ...
Don Lewis
I had a customer years ago who made barnboard paneling from new pine boards. He used a pressure washer on green boards and then dried them. It was a successful product line at that time (early 1980s)
5/20/18       #6: Rough Sawn ...
Robert Ross Member
Website: http://wc-hardwoods-sawmill.blogspot.com/
I have a 20" floor model bandsaw in the shop, and when I want a ruff texture on the wood I drag the board backwards at about a 30 degree angle or so across the blade teeth, and of course it wont saw, but it does leave some nice texture on the face of the board. Now I use mostly a 1/4" skip tooth blade with 4 teeth per inch.
