Sawing and Drying
RE: Bandsaw blades breaking
5/18/20
Tommy Hart
We have an American Bandsaw Mill, with which we have been cutting hardwood logs for the last 12 years.
Unfortunately, this last week, we have been breaking bandsaw blades very quickly. Usually we get 3 to 4 sharpenings out of the blade before it breaks.
This past week we are breaking new blades on the first cutting.
If anyone could shed some light as to why this is happening, we would greatly appreciate it.
Thanks,
Tommy
5/18/20       #2: RE: Bandsaw blades breaking ...
Tommy Hart Member
To the original post....
I just wanted to add that the bandsaw mill is a relatively large horizontal sawmill with a band blade of 19' 6" and has 30" wheels.
Also, it has a powerful 86 hp Cummins diesel engine which can handle logs of 30" to 32" in diameter, and 21' long.
5/19/20       #4: RE: Bandsaw blades breaking ...
Jim Member
Are they breaking at the weld?
5/19/20       #5: RE: Bandsaw blades breaking ...
Tommy Hart Member
The blades are breaking in random areas, but not at the weld.
5/20/20       #6: RE: Bandsaw blades breaking ...
Mark Hineman Member
It sounds like you are sharpening the blades yourself.
As I understand "micro fractures" occur at the bottom of the gullet. If your setup includes a well dressed grinding wheel, and you are getting a good grind at bottom of the gullet, it should clean up those fractures.
Otherwise the fracture continues and the blade breaks
5/20/20       #7: RE: Bandsaw blades breaking ...
If your blades are breaking brand new and not at the weld would assume youve checked all the usual suspects, blade tension is correct, guides are correct, operator is not slamming into the end of the log, not crowding/over feeding, and so on. Outbound of that I would be contacting your blade supplier or trying a few blades from a different supplier to see if somehow you got a bad batch of blades which would seem odd.
Ive read and been a part of a bunch of conversations pertaining to what Mark mentions about micro fractures but you say they are breaking on the first go with a brand new blade. That wouldnt really pertain to re-sharps. I always grind/ground our full profile (hook, rake, and full grind on the gullet) to address the micro fractures but I know a ton of guys who sharpen, or have their blades professionally sharpened that may only grind the hook face or the hook face and the top of the rake and swear they have never had an issue. I prefer the full grind but given the experience others mention and the speed of not grinding the gullet who knows.
Theres not a lot of factors if its happening with new blades. Blade material, mechanical issues, or operator error.
5/31/20       #8: RE: Bandsaw blades breaking ...
GeneWengert-WoodDoc
I assume that you have the correct width of blade for your machine. If you are breaking a blade at random places, either the blades are junk or you have way too much tension. Normally, feeding to fast would stall the motor,
6/9/20       #9: RE: Bandsaw blades breaking ...
Eric Steadle
If it was working well, and now it's not, something changed. If it's not the bands (new supplier, etc.) then look for what else may have changed. Consider that something may have broken or failed.
Examine the tracking plate closely on the idler wheel... you may find that it has weakened, or one of the hinges has broken. Perhaps it was bumped by a machine and knocked out of true by a log.
Check for loose or perhaps broken bolts that fasten the tracking plate to the frame. Also check that the idler wheel bearing is spinning freely. These are often "sealed" bearings and they have a lifetime. After a couple 1000 hours you'll need to replace it.
On the drive side, check the main bearings and ensure they are rotating freely, the shaft is true and not bent. Check the grease fittings (usually dashpots) and make sure they are pushing grease into the bearings.
After all that, check your bandwheels to ensure they are co-planer. Lay a straight metal level or ruler horizontally across the face of the bandwheels about 1/3 of the way down from the top, and above the axle. Look closely at the 4 outer edges of the bandwheel that touch the straight edge, and check for any gaps between them. Do this again below the axle 1/3 of the way, and check again.
If you find any gaps, you should adjust the bearings or the tracking plate to get them dialed in. If bandwheels are not perfectly co-planer, the band stretches unevenly from front to back as it rides around the wheels and those stresses will cause metal fatigue more quickly than normal. Sometimes you can look at the blades and see very slight cracks in the other gullets of a failed blade, or on the backside of the blade working its way toward the gullet. If you see this in your broken blades, it's a sign that the bandwheels are not co-planer and need to be adjusted.
Also check your roller guide bearings and make sure they are not seized. (You'd probably have noticed that as they tend to scream when they won't turn.)
Post a picture of your broken edges of the blade and someone can probably tell whether it broke because of stress fracture or from fatigue. That will help narrow it down at least.
Best of luck to you.
12/22/20       #10: RE: Bandsaw blades breaking ...
Rooster Member
Tom do you get any push off or diving on the end of cuts could be out of square blade guides putting stress on your blades I have a woodmizer Lt 70 or blade too far away from the bearing shoulder
    • Forestry.com
