Sawing and Drying
Need a mill to cut 5,000-10,000 BF per day
9/19/22
Mark Member
Hello,
Does anyone know of a mill that can cut 5,000-10,000 bf of southern yellow pine per day? I have heard of a brand of mill called "cedar mill" that is a band saw mill. They claim that it can cut this amount. Does anyone know anything about this type of mill and if this number is accurate?
Thank you
9/20/22       #2: Need a mill to cut 5,000-10,000 BF ...
GeneWengert-WoodDoc
It depends on the ability to supply enough logs so the mill is running. It depends on the length of time you are running, such as 40 hours a week or 50 hours or 80 hours. It depends on the log size. It depends on if you produce a cant. It depends on the thickness of the lumber. It depends on the acceptability of all pieces of lumber.. it depends on the speed of the graders.and stackers. It depends on if you have a large resaw to process cants into lumber in one pass…a cheaper approach than trying to saw all lumber from the head rig. It depends on the wate conveyor size.
Having said all that, do you want just a head rig, such as WoodMizerr, or are you looking at the entire package?
9/20/22       #3: Need a mill to cut 5,000-10,000 BF ...
Mark
There will be plenty of logs. . Will run at least 40 or 50 hours per week. . Log size will vary but will probably can't out to at least an average of 12" or greater, and will be cutting 4/4, 10.5"-14" wide boards maybe a little more or less. . I'll be operating this head rig that the maker says can cut a minimum of 5,000 bf in an 8 hour work day of 4/4 no problem.
9/21/22       #5: Need a mill to cut 5,000-10,000 BF ...
MarkB Member
Every band mill mfr will give you optimal per hour ratings for their mills at a given thickness. You can search the portable mill shootouts to see what machines up to like an LT70 will produce fully tricked out. I would think that would be the class machine you'd be looking at whether its portable or fixed and electric or diesel. Last I recall machines in that class are in the 1000-1500 bd ft/hr range which being realistic would likely put you right in the middle of your target on an 8 hour day.
5/4/24       #7: Need a mill to cut 5,000-10,000 BF ...
TRTermite Member
I used to cut 4 to 10K ft a day on a hand set #8 Corley belt driven 56" F (?52 tooth) 8/9 ga mill all logs turned with a cant hook or big one used the loader, 3man crew of sawyer (Me) the edgerman and a stacker. 8 HR DAY 5 DAYS A WEEK. average was well over 4K but some days 10K . Straight medium size logs made a huge difference. Pallet lumber cottonwood.
Once in a while my dad would send the his guys home after the week tallied 15K, the mill was cleaned and logs on the deck for Monday He would make a disclaimer if the logs were great and point at a few bunks of ROUGH logs inferring he could adjust the outcome.
    • Forestry.com
