Sawing and Drying
New Sawyer w/new solar kiln needs help
2/20/23
Rod Finch  Member
Hello, I bought my saw approx. a year ago, cut up some slabs and built a solar kiln, almost to the Virginia Tech specs. I am located in mid-Texas, a little West of Ft. Worth. My kiln, which is finished (except for cosmetics), will rise to 175F on a clear day with an ambient temp of 70F. Around here your 70F one day and 32F the next. The bugs here love my wood, and I hope to sterilize it w/Kiln. I am looking for any help in using it and deciding on a good moisture meter; I have a cheap $50 one. I have been looking at the Delmhorst J-2000, but that's a lot of money for me. I have several types of wood, got a deal on a bunch of Pecan from an orchard, and have access to several large Mesquites. I have been cutting 8/4 and 10/4, and I also have some Post Oak. Any advice would be greatly appreciated. Thanks in advance for your time. Rod F.
2/20/23       #3: New Sawyer w/new solar kiln needs h ...
I suppose you have this guide to operation of the Virginia Tech kiln? Lots of videos on YouTube and Google.
https://www.pubs.ext.vt.edu/420/420-030/420-030.html
2/25/23       #5: New Sawyer w/new solar kiln needs h ...
Rod F  Member
Yes, Sir I do, but for the life of me, I cannot understand the math equations.
2/27/23       #6: New Sawyer w/new solar kiln needs h ...
Mark Rodriguez
I bought a Delmhorst moisture meter J-2000 used for $190.00 on Facebook. It works well. I would suggest that you air dry wood first - sticker every 18", cover with tin, weigh down stack and measure the MC every month or so and mark with date and MC on the side of each board. Once the wood gets to 12-15% put it in the kiln and measure each day or two until wood down to 8%.
Once its 8% the wood should be good. The high heat for a day or two will kill any bugs.
2/28/23       #7: New Sawyer w/new solar kiln needs h ...
Rod F  Member
If I air dry until it is down to 12-15%, that will take a couple of years. I thought the whole idea of the solar kiln was to speed things up. Maybe I missed something; I was under the impression that you air dry for around a month, then the solar kiln starting low and bring it up, say, over a couple of months.
3/15/23       #8: New Sawyer w/new solar kiln needs h ...
kalcolm Member
Xiaomi smart temperature and humidity meter has a soft price but a lot of outstanding features. The ability to measure specifically to 0.1℃, 1%RH will help you understand the temperature and humidity more accurately. The device can also connect to a phone application for you to easily monitor temperature and humidity more easily. When the temperature and humidity are out of the comfort zone for the child, the app will automatically prompt you to make timely adjustments. The display of smileys and smiley faces also makes it easier to recognize the state of the air in the room.
3/19/23       #9: New Sawyer w/new solar kiln needs h ...
Chippy1987 Member
Not the advice you are after, but YouTube is always one of the places I would look to find out more and to learn more. I heard Tavool is an excellent product to consider.
    • Forestry.com
