Solid Wood Machining
Cantek EM-12 Endmatcher
3/27/14
J
Anyone have any experience with Cantek EM-12 end matcher? We just bought one a few moths ago and we are having problems getting it tuned in. It runs great when working properly but when it has issues its a pain to get set up, factory set up the machine and we are stilling having issues. Just curious if anyone has any experience with this machine or insight. We have a bunch of flooring stacked up and need to get it running.Our current issue is the grove side of the match, it is not square off by about a 1/16", seems like the side clamp is not applying enough pressure, have tried all the obvious but running out of ideas.
3/30/14       #2: Cantek EM-12 Endmatcher ...
Dale F. Victor
Website: http://www.dalefvictor.com
Hello!
I looked up how the machine is supposed to work and it seems to me that if it is not cutting square and the wood is being held the way shown then the only thing that can be our of adjustment is the mechanism holding the cutters. There must be some way to adjust this mechanism. If the clamps were not tight enough then the piece of wood would move and you would know for sure this was the problem.
5/22/18       #3: Cantek EM-12 Endmatcher ...
doug alward
try checking the plastic ware rails at the front and rear of the hold down on the groove side they tend to open up and allow side to side movement of the hold down causing an out of square condition when the board is pushed into the cutting position.
