Solid Wood Machining
SAC Planer problem Table Lift
4/17/14
Paul Marshall Member
I acquired new 05 model 20" SAC planer and can't get the table to move. It was working fine a couple of day's ago. It's stuck in down position. Maybe there is a reset somewhere? Fuse? It won't respond to up or down switch or pushbutton. The manual is not much help. Everything else is working fine (power motor, feed, etc.) If anyone has any idea's I would greatly appreciate it. I am running phase converter.
4/27/14       #2: SAC Planer problem Table Lift ...
Correy Smith
Paul, powered tables?
On my griggio the table lift is done with an independent motor. The motor turns a small wheel about 1" in dia. This turns a larger wheel connected to the helical drive of the screws that make the table travel up and down.
On mine, if I max out the Down, like tightening a bolt it will stick in the down and the small rubber drive wheel will spin on the larger wheel.
Now be careful, if you hand turn the larger wheel as push the up button you should be able to free it. just don't get pinched or fingers in somewhere where it will hurt.
4/27/14       #3: SAC Planer problem Table Lift ...
Paul
Thank you for your response. Turns out I have a bad 3 position switch. Switch will not stay in vertical position which would be off. So, switch is either selected to go up or down and table will top or bottom out until the corresponding fuse blows. I ordered one off ebay. I will find out soon if this is a fix. I hope so.
