Solid Wood Machining
Tenon heads for 10hp SCM T130
5/2/14
Correy Smith
What are some realistic expectations for milling 4" tenons with tenoning head with a 10hp shaper using a sliding table? For a moderate hard wood can I do this in a single pass? What is an expected feed rate?
Manufacturer you might recommend?
Thanks for any experience you might share on this.
5/2/14       #2: Tenon heads for 10hp SCM T130 ...
Brian T
Yes 4 inch tenons are fully possible in one pass with this class of shaper. You will be turning a 10'' head to achieve this size tenon so run the shaper on the lowest speed. Feed rate will be very slow and will vary with species and materials.
If you don't have a separate tenon shroud for the shaper then make one. Covering as much of the head as possible.
Call Schmidt and get some ideas. There are plenty of other companies that can supply this tooling as well.
Are you making window sash? Do you really need a 4 '' tenon?
Are standard entry door and sash set that were made 20 years ago cut a 2.5'' tenon at the daylight. These sets go from 1.375''-2.75'' in material thickness.
Most of our doors and windows are located in New England Directly on the water and are built from Mahiogany. We have had one failure in 25 years and that was related to a failure with the West System Epoxy not the joints. We have on occasion needed stronger joints with very large doors (10'tall 4'wide or wider and 2.5'' thick and up). In this instance we use large spline joints 1'' thick as deep as the mortiser will go.
5/2/14       #3: Tenon heads for 10hp SCM T130 ...
Correy Smith
Hello Brian, Thank-you very much for the info. Yes , I have a few large entry door jobs this year. I was hoping the tenoning head would reduce time from the BS cheek cuts and TS shoulder cuts.
Unsure of how many jobs it will take to pay for itself.
I also like making doors with twin tenons and will be looking into sets with a third plate in the middle maybe an adjustable groover so I may adjust the spacing between the tenons?
5/2/14       #4: Tenon heads for 10hp SCM T130 ...
We do almost all our tenons on a Powermatic 2A with air clamps, Schmidt insert heads and new bearings throughout. We only have the two tenon heads - no coping shafts or motors. The addition of the two digital readouts means we can set it up in under 3 minutes, accounting for the 8 thou fitting adjustment as we go.
Many of our tenons are coped on the shaper, so we will first tenon about .030 thick on each face and remove 80% of the wood - on the tenoner, then finalize it with the cope discs on the shaper.
It is rare for us to need 4" long tenons, since the coped surfaces add quite a bit of glue surface.
