Solid Wood Machining
molding on a 3hp shaper
10/18/14
Farms100 Member
I have a run of several different profiles of maple molding. The most aggressive cut needs a rabbett 2 1/2 inches tall and 1/4 deep.
I don't have moulding head or straight cutter tall enough to do a test cut. is this feasible to do in one pass?
10/20/14       #2: molding on a 3hp shaper ...
D Brown
Depends on what type of wood you will run
surely you can make 2 passes .
12/7/14       #3: molding on a 3hp shaper ...
You should be able to make multiple passes if you make fences to support the work properly. tack a support strip on the out feed fence to fill the space taken away by the cutter. If you use a shaper much you should probably buy a heavier one. 1 1/4" spindle and at least 5hp. I see used SCM shapers fairly commonly. They are good solid standard machines. Gomads are less common but good machines, usually cheaper because they are less known.
