Solid Wood Machining
dual hook heads
10/23/14
doug mclaren  Member
anyone have experience good or bad with titan heads. i'm looking at schmidt ,titan, and possibly tersa. i will mostly be doing s4s but occassionaly t&g and flooring.
10/23/14       #2: dual hook heads ...
Russ
Website: https://www.mirror-reflections.com
I have sold many of these cutter heads over the years, never had any issues. The other brand names you mentioned are also very good quality, so the decision you make will be a good one no matter who you choose, most manufacturers are held to high quality tolerances, check out Weinig as well.
Dual angle would be my preferred choice. I hope that helps.
Good luck!
10/26/14       #3: dual hook heads ...
Correy Smith
I went with Schmidt, It's very nice.
Depending on the size of head you get some segmented gibs with it . i.e. the 3" come with two 3" gibs , two 1" and two 2" for running shorted knives in the same head.
I was always told you should load full width knives in the head but schmidt says it's fine. They also say that you don't need to put blanks in the empty slots, but I found that only loading two knives will distort the head pretty easy and make it impossible to get on the spindle.
Russ, your link isn't taking me to you sight. Hoping to use you on my next knife order. I hear you do great work.
10/26/14       #4: dual hook heads ...
shaner
Yes give Russ a chance for doing any drawings template and of course knives. His work is second to none and have used him since I got started in 2008. He has been very helpful in also selling tooling as well when I needed something or even some trouble shooting on the moulder. So much knowledge from a great guy who can make most operators better without even training them in person. His website is also great for information to learn about mouldings and grinders.
11/11/14       #5: dual hook heads ...
Joe Member
i think you can find his contact info on his you tube videos , also very informative...
1/2/15       #6: dual hook heads ...
Correy Smith Member
I know this is an older thread now, but I saw some heads on the Weinig site for shapers. Anyone try them?
1/3/15       #7: dual hook heads ...
Mary Moore
Website: http://moulderservices.com
We have American made heads that have over 20 years of history in the woodworking industry. Our president has several patents in cutter head design including one for dual hook heads. He is always glad to speak with woodworkers to help them determine what they needs are. We also make the shaper heads for all types of machines.
Cutterheads
