Solid Wood Machining
What is the best planer?
10/24/14
Ben Member
I am looking for some advice from any of you who have experience with large planers. We run flooring from reclaimed lumber and we are going to purchase a new or used planer 20-50hp. We are currently running 2000 square feet per day through a PM 221 with shelix head. It works great but we need to speed up the process. Im not opposed to an older machine but I dont want a maintenence hog. I definitely want a helical head due to the nature of reclaimed wood. What are the best options out there??
10/25/14       #2: What is the best planer? ...
Look at the older Newman-Whitney top and bottom planers. One pass and you are ready to send it to the molder. 2,000 s/f a day is less than an hour's work for the aforementioned beast.
Check with the advertisers here on Woodweb for availability and price.
View larger image
Planers
10/30/14       #4: What is the best planer? ...
Brian T
I mill quite a bit of reclaimed stock now. If I were to invest in a machine for reclaimed it would be an abrasive planer. Usually 25'' - 37''. Large motors. 50 hp and up.
Most have 2 heads. A steel drum and a rubber or combi second head. With this machine there are no teeth to replace when milling old nails and the like.
In my humble opinion it seems like the simplest solution for reclaimed materials.
You can also find combi machines with shelix heads and abrasive belts second.
11/5/14       #5: What is the best planer? ...
Gene Wengert-WoodDoc
For planing rough lumber, I like the Newman 282. Carbide spiral head is a must.
For a cabinet planer, Weignig has some good ones.
