Solid Wood Machining
is this junk?
4/27/15
mike
Is it junk and if not, is it a good price?
What else is on the market?
They show someone making a small box in length. I want to do up to like 8ft long pieces. Does anyone know of a (Chart) of some sort to give u an idea of how long and about what temp you want to steam different types of woods, thicknesses and sizes?
Steam Bending Kit
4/28/15       #2: is this junk? ...
Rob Scaffe  Member
You can go to Lowes and pickup a unit similar to this in their paint department for steam removal of wall paper. It is very convienent and works well. Make your own box depending on your needs, you can also use large PVC pipe for box.
4/29/15       #3: is this junk? ...
mike
Thx bob. Im still looking to see if theres something online to basically " teach" me how to use it based on different size and thicknesses of wood and if theres some formula, based on the size of the steamer to know how big of a box i can make, per the output of the steamer
4/30/15       #4: is this junk? ...
Mel Member
Mike--is there a boat yard close to where you live? Those guys are the authority on bending wood. And always willing to indulge a passer-by with questions (especially if you have beer).
Use to live on a boat yard--one of the shops actually had a plywood box with a disabled-stop tea kettle for thin stock (kayaks and what-not). As for larger, thicker stock, the housing would be out of stainless or ceramic, with actual boilers.
Up to you how McGyver you want to get for your first trials--but yeah, boat yards in IMO the resource on the topic.
Forest Service Handbook
5/1/15       #5: is this junk? ...
Rob Scaffe
About an hour per inch of thickness is rule of thumb. You simply need to saturate the box with steam. For my first experience with this, I simply put some water in a 55 gal drum on blocks, built a fire under it with wood scraps, screwed a short pipe into the bung hole the other end into the box made of scraps. a teapot with hose, whatever, you just need to boil water and vent it into a box, no more complicated than cooking a pot of grits, (I happen to be a southerner).
Green wood works best, but whether green or dry, you are going to need straight grain, split from the log is best. My advice is just to gather up the materials and have at it.
5/2/15       #6: is this junk? ...
Mel Member
Rob-- I love this sort of stuff. Any chance you have a picture, for the curious? Or even a simple drawing?
Cheers :)
5/2/15       #7: is this junk? ...
Rob Scaffe
The small one is shown with the Wagner wallpaper steamer, works great and convienent. The one outside is a bit larger, the dowels are to keep the wood out of the condensate. I tend to just knock these things together as needed. Some use PVC pipe. A piece of large diameter pipe from a scrap yard would also work well. Just depends on what you are trying to do and how often.
5/4/15       #8: is this junk? ...
Mel Member
Do you also use the Wagner on the bigger one?
2/23/22       #9: is this junk? ...
Janine Ferguson
