Solid Wood Machining
taking 2x6x16' to 5/4" x 6 decking on moulder
6/17/15
Rusty L Member
Guys,
Any idea for knife marks per inch for running 5/4" premium decking out of 2x6 SYP ? our minimum width is 5 7/16". Any advice or machining help would be appreciated. We are planning on running both side heads obviously for roundover, and one top head and one finish bottom head. I am trying to figure out feed rate.
Thanks,
Rusty
6/18/15       #2: taking 2x6x16' to 5/4" x 6 dec ...
Jason
You can calculate that. Multiply cutting knives( non jointed=1) x spindle rpm and divide that by your feed rate in inches.
I.e. a non jointed moulder with 6000 rpm spindles running at 30f/m will give you between 16 and 17 kmpi. Wich is pretty good.
6/21/15       #3: taking 2x6x16' to 5/4" x 6 dec ...
Dustin orth
Why not resaw off a bunch of the extra then run on the molder? Seems like that might save on a few things, extra sawdust, feed speed increased due to not having to cut as much and maybe someone could use the thins as veneer. Just a thought.
6/21/15       #4: taking 2x6x16' to 5/4" x 6 dec ...
Rusty L Member
Thanks for the responses! Happy Father's Day!!!
