Solid Wood Machining
SCM SI400 NOVA
7/17/15
sol Member
we are looking to buy this machine
we are a small shop and have maybe 2 hours for use on the machine or 3 hour per a day
can anyone tell us if there is a reason not to get the machine
thank you
7/20/15       #2: SCM SI400 NOVA ...
correy smith
Website: http://www.matsukazewoodworking.com
Hi Sol. I bought one last November.
It's a good saw for the price. SCM is using the same slider on all saws now except a one or two models that used the radiused ways instead of the v way. Most companies use the v way including Martin. It's a solid carriage. The Nova 400si is scm's entry level saw. Lacks electronics and cnc fences. They weigh about the same as other class saws and within a couple hundred pounds of an F45 but unsure why people obsess about weight seeing that 90% of what you do is on the slider.
I tried out the slide on a Nova 350 that was 5 years old and it was smoother than the F45's I was looking at
I think a few things are a bit heavier on the class models, the fence rail maybe a bit larger in diameter, the fence body maybe a little bigger. The chassis has more labor in to it. But none of this affects function.
It makes accurate cuts. I looked at the wa-8 and this saw seemed every bit comparable for almost half the price.
The trunnions work easily. Plenty of power , 10hp. Love the riving knife and that you can use 12~16" blades.
Great over arm blade guard. Dust extractions o.k. but would do better if I had a bigger DC in the shop, it's at the end of a long run.
It came pretty well plug and play. Mount the guard, fence, out feed tables, and slider, then plug in. It took about 6 hours at a slow pace to uncrate and set-up the saw.
Accessories and options are best ordered with the saw. You can get them cheaper that way usually. I ordered a miter fence and got that about half off list. Other things like digital stops are best ordered as an option but then your not ordering the promo machine any longer. The nova with the cnc was much more so I will eventually add tiger stops. The benefit is that if the electronic fence fails, at least you have the analog fence for back up and don't have to stop production while you wait for solutions.
SCM has a pretty good parts department here in the US. But still maybe better to order from a vendor as SCM only sells at list price.
Some private vendors get better deals than others because of the volume they move. So shop around. I bought mine for less than the advertised promo price and the shipping was less than half of anything I could find.
It's a great tool. I am a one man shop and work primarily solid wood building high end furniture. Glad to be rid of the crosscut sleds on the unisaw. I did keep the unisaw for dados and production ripping of millwork blanks. The nova will not take a dado blade.
I also enjoy the slider for straight lining lumber. I use it for most any cut now but try to use the chop saw for cheap quick cuts. Interestingly my electric bill has not really changed since installing the 10hp compared to the 3hp unisaw it replaced.
I think it saves me the six hours a month that equals my payment on the machine.
If you send me a note with your zip code I will see If I can get you a similar deal to what I had.
Good luck,
Correy
7/21/15       #4: SCM SI400 NOVA ...
sol Member
Hi
thank you so much for the info
my zip is 11218
