Solid Wood Machining
Delta 20" Bandsaw Tire Replacement...
7/23/15
JeffD
I kicked my bandsaw on this morning to do a quick cut and the thing jumped, slammed and the upper blade guard came crashing down! I shut it down and started to investigate and the entire bottom tire was folded up and jammed into the upper guard!!!
Anyway I did a quick search online and the tires seem to be available….which in itself is amazing since they're Delta parts. Unfortunately they're also about $171 a piece! It's an 02' machine so figure if one is gone the other is right behind it, so I'd want to do them both. But that's a lot of cash for a couple tires! So if anyone has any other sources for Delta tires they'd be willing to share I'd love to hear about them.
FWIW these saws use grooved wheels. The tires are pre-crowned and have a tongue on them that fits into the wheels groove. Not sure how popular this system is and whether any other manufacturers use it….but with my luck probably not.
thanks,
JeffD
7/24/15       #2: Delta 20" Bandsaw Tire Replace ...
Carter has this kind of thing in a few versions. They seem to know a lot about bandsaws, and their guides are the best.
Carter Band Saw Parts
7/26/15       #3: Delta 20" Bandsaw Tire Replace ...
JeffD
Thanks Dave, I didn't see what I need on their website, but I'll give them a call this week.
JeffD
7/30/15       #4: Delta 20" Bandsaw Tire Replace ...
Bob Vaughan Member
Bobby at Woodworkers Tool Works deals with this specific problem all the time. Give him a call.
7/31/15       #5: Delta 20" Bandsaw Tire Replace ...
JeffD
Thanks Bob, I called a few places including Carter with no luck. Someone recommended Sulpher Grove Tool and they had a urethane version with the tongue on it. Got them installed the other day and they seem to work OK so far. Will have some re-sawing to do next week so will do a more thorough test drive.
JeffD
