Solid Wood Machining
Carbide alternative
8/5/15
Jay
I currently use carbide inlay straight knives on my moulder for s4s in hard maple. I like the carbide because I don't get the dull spots or nicks from the mineral spots in the wood like I would if I use HSS.
I'm not real happy about the finish though. Often the wood fibers seem to get pushed out to the side leaving a fuzzy edge.
Does anyone know of a different grade of steel that can stand up like carbide but give a nice finish like a typical M3 does?
Thanks for any responses
Jay
8/5/15       #2: Carbide alternative ...
Dan
Website: http://www.ctsaw.com
Have you looked into using a surface treated steel like Wisconsin Knife Works OPTI steel? The face of the knife is specially treated creating an ultra hard surface.
This material is designed specifically for natural woods where you need the finish quality of HSS but with more longevity - so S4S straight knives are a good fit for this product. One thing to note is although this material grinds like regular steel you need to make sure you do not hone the face because doing so could remove the surface treatment.
Feel free to reach out to us if you need some more help.
8/5/15       #3: Carbide alternative ...
Russ
Website: http://www.mirror-reflections.com
Jay
Opti, black nitride, both the same finish process but prone to chipping especially on knotty alder, although great for other hardwoods.
We have an Endurance knife steel which many vendors sell, its coated with diamond dust but can be ground with a convention Borazon wheel, pricing on our website if your interested, we can supply you with a bunch of contacts who currently use this product if you wish.
All the best
Russ @ MR
8/5/15       #4: Carbide alternative ...
Jay
Russ I have just learned about that endurance steel. I would love if you could provide me with contacts of people who use this! Thank you!
8/24/15       #5: Carbide alternative ...
Depending on your volume you may want to get a head made. We have a head we use to trim the edge of hardwood. We had it made by Great Lakes Tool. It is insert carbide. It has knives that are at a shear angle to the edge. One from the top one from the bottom. Sort of like a compression bit. It is pricey but does a significantly better job than a straight knife.
