Solid Wood Machining
Moisture Meter Setting
9/8/15
Kevin Member
I use a Ligno pinless moisture meter. There are two depth settings, 1/4" and 3/4". For lumber that has been milled to 13/16, is the 3/4" setting going to yield more accurate results? I'm wondering because two bundles I just received read 8-10% at the 3/4" setting. When checking at 1/4" setting, there are no readings over 8%. Which setting do you think is a better gauge of moisture content for this thickness? Thanks.
9/19/15       #2: Moisture Meter Setting ...
Gene Wengert-WoodDoc
Do you have an air space under the piece you are measuring? This is important.
