Solid Wood Machining
What brand shaper cutter do I have
9/8/15
Duane Member
I purchased a used three used weaver shapers to add to my custom door shop and i=I am trying to figure out what brand the insert shaper cutters are that cane with them. I've been using freeborn insert cutter heads on my other machines but the cutters that came with the shapers I purchased have a 5 or 5.2 mm cut for the panels. I need to find out what brand they are so i can start getting my 1/4 plywood locally since true 1/4 plywood is getting hard to find.
9/8/15       #2: What brand shaper cutter do I have ...
JR Rutter Member
I would guess Superb, since that's what is etched on the inserts...
Superb
9/8/15       #3: What brand shaper cutter do I have ...
Duane Member
Thanks, i don't know why but i couldn't come up with anything on a google search.
9/9/15       #4: What brand shaper cutter do I have ...
Russ
Website: http://www.mirror-reflections.com
I recognize the numbering system
Superb tooling 812.367.2102
But probably made by Dimension in tooling in Indiana
http://www.dimensionsintooling.com/
Hope this helps
Russ
http://www.superbtooling.com/index.html
