Hitachi cb75F resaw -- 2 --
9/18
I picked up this used resaw and I am new to resawing. First the blade that comes with it is 3" wide. I can't find anyone who sharpens these. Any suggestions? The saw is underpowered but I will eventually replace it with bigger motor. We are not looking to do huge amounts of re sawing but could use some pointers and advice.
9/19 #2: Hitachi cb75F resaw ...
The place you need to send the blade(s) for resharpening is a place that sharpens bandsaw blades for larger sawmills. I send mine to a place in Maine.
There is a kit from Hitachi available to retrofit the machine with different guides so that you can fit smaller blades. A 1" blade would also be fine for resawing, especially since the Hitachi machine frame is more than stiff enough to handle the tension, and the blades are cheaper and can be sharpened anywhere.
For resawing, it is also handy to have the extension arm set with outfeed roller, also available to buy on amazon, etc..
If the blade is sharp, I do not find it to be underpowered, however I do find the gear reduction motor noisy. There was a version from Hitachi with a 3-phase motor, no gear reduction, but it was never sold in N. America.
9/19 #3: Hitachi cb75F resaw ...
Hey thanks for the info. I picked this saw up for $300 so I figured I could put some into it and make it work for me. We don't do a lot of resawing, but for making some matching panels and some other work I felt it would be a good addition. What was the company in Maine you were referring to? I can't find anybody local who sharpens band saw blades.
9/19 #4: Hitachi cb75F resaw ...
When I had a Wadkin PBR, I sent the 3" blades to Menomineee Saw in the UP of Michigan. They could sharpen, repair tips and re-tension a blade. I'd let 3-5 get dull then pack them up and send them - not easy, but far cheaper than buying new.
Most band saw blades are looked at as disposable so sharpening them is rarely done, unless it is a band mill blade like for sawmills.
9/19 #5: Hitachi cb75F resaw ...
Ok. Thanks for all the advice. I looked at youtube and saw a guy sharpen his with a dremel and small sharpening stone so I thought I would give it a try. I couldn't believe how much better it cut afterwards. Just a touch on the tips and gullet and it was 100 times better than before. I will still send it out for resharpening and retensioning but this will get me a little more time out of the blade before then. I am going to try the ones for bandsaw mills as suggested.
3/16 #6: Hitachi cb75F resaw ...
I have been using a Hitachi CB75F for many years now. Anyone have a source or experience with alternate sources for blades other than Hitachi?
4/28 #7: Hitachi cb75F resaw ...
I am currently working with the people at Wood-Mizer to make me some custom blades , 111" long, 2" wide, Stellite tips, .042" kerf. Box of 5 blades would be $391.00.
This would be hugely more economical that Hitachi's $220.00 each price, and Wood-Mizer would be able to sharpen them.
Please note I have NOT tried this yet, but I will order one as soon as my other blades are dull.
9/11 #8: Hitachi cb75F resaw ...
To follow up on my last message, I have ordered the stellite sawblades from Wood-Mizer. I was wrong about the kerf, now they are telling me the kerf will be about .080" and the band itself will be .045". This is quite a bit more than the original Hitachi bands, but still far less than the blades on my 30" wheeled bandsaw.
I am now looking for someone to sharpen my old Hitachi blades, anyone have a good vendor for this?
2 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
