Solid Wood Machining
RE: Wide Belt Sandpaper
9/24/15
Tommy Member
We have a 37" wide belt sanding machine.
We were wondering what company(s) provide high quality circular wide belt sandpaper that measures 37" x 75" and has grits from 30 to 230.
9/25/15       #2: RE: Wide Belt Sandpaper ...
Kevin Jenness
We use #M clothbacked belts. Not sure about 30#, but we do have some 60# and 36 or 40 is probably available. Very high grits like 220# require careful setup to avoid burning. We rarely go above 150# prior to random orbit sanding.
9/25/15       #3: RE: Wide Belt Sandpaper ...
Kevin Jenness
I would add that if you are new to using a wide belt you can find some excellent inormation at the surfprep sanding website.
9/25/15       #4: RE: Wide Belt Sandpaper ...
andy
Klingspor
9/27/15       #5: RE: Wide Belt Sandpaper ...
Adam West  Member
Thank you, Kevin.
Tommy, Message me if you would like some information on wide belts and sanding. I can help you figure out what you need.
10/10/15       #6: RE: Wide Belt Sandpaper ...
B.H. Davis
Website: http://www.curvedmouldings.com
I use these folks. Good quality and fast service.
Industrial Abraisives
