Solid Wood Machining
Manual for Rondamat 925
10/8/15
scott Member
I am buying a used Weinig Rondamat 925 to cut knives for an old Weinig molder. Does anyone have a manual either hard copy or electronic that I could buy? I don't know the first thing yet about knife grinding yet, so want to at least start with the manual.
10/10/15       #2: Manual for Rondamat 925 ...
Rob Scaffe
You can get one directly from Weinig if you don't mind paying for it..
704 799 0100
10/11/15       #3: Manual for Rondamat 925 ...
scott Member
thanks I am aware of that, I was hoping someone had a manual they did not need or electronic copy they could share.
10/11/15       #4: Manual for Rondamat 925 ...
Russ
Website: http://www.mr-moulding-knives.com
The Rondamat 925 is one of the most difficult grinders to grind moulding knives on, there is a lot of little things you can do to make it work more efficiently.
I agree with Rob, buy it from Weinig it will provide you some basics but it doesn't really go in depth on how to master the machine.
You might contact Rob and have him come train you how to properly use the machine, he is one of the best out there.
We have some articles on moulding knife grinding on our website, they are more focused on the Weinig R-960 but the principals are the same.
Hope that helps you some
Good luck
Russ
