Solid Wood Machining
Band Saw Guide Bearings
10/9/15
Geoff
I have a Powermatic band saw model 2415 and am looking for after market guide bearings. The lower bearings are the ones I want to replace. The stock set up seems poorly designed.It is hard to adjust and the bearings are oriented 90 degrees different then the top bearing. The top bearings the edge of the bearing faces blade and turns when touched. The lower bearings the face faces the blade, when touched they don't even turn.
Anyway, if anyone knows an after market set up or has found another solution, that would be great.
Geoff
10/10/15       #2: Band Saw Guide Bearings ...
bob
carter guides - only
also search woodweb for video of adjustment, this guy is great
10/12/15       #3: Band Saw Guide Bearings ...
Bruce H
Carter Guides are what you need!...
Watch this video, you'll become an expert.
Band Saw Clinic with Alex Snodgrass
10/13/15       #4: Band Saw Guide Bearings ...
Geoff
Great! Thanks.
