Solid Wood Machining
General 10" tablesaw alignment
11/5/15
dave Member
I have an older but mint 350-1 General 10" table saw with a problem I'm not sure how to fix.
The blade is aligned with the miter gauge slot and with the fence when in the 90 degree position.
But when the blade is swung to 45 degrees it is out. It closes in to the fence at the back. Secondly, I notice a fairly heavy vibration, although the spindle has no run out. Mostly concerned about the alignment issue for now. Thanks for any thoughts.
11/5/15       #2: General 10" tablesaw alignment ...
It is likely that the trunnions are not aligned vertically with the table. The table is bolted independently to the saw from the trunnions. If the measurement of the table top to the front trunnion is different from the top to back trunnion, the saw may run true at 90 degrees but bind at 45. The solution is to shim the table front or back between the chassis and top until the mitre cut runs clean. If the saw binds on the right during the mitre cut the the rear of the table is high. If the left or top of the mitre cut is binding then the front is high.
The vibration may be caused by poorly aligned motor, worn or mismatched belts, cheap sheaves, etc. Start with aligning the motor and checking the condition of the belts.
11/5/15       #3: General 10" tablesaw alignment ...
dave Member
So Tom, if the measurement from a blade tooth, at the back of the saw blade, is less to fence than the front tooth to fence, measured on the table top plane. The top is higher at the back?
11/6/15       #4: General 10" tablesaw alignment ...
I knew I should have been clearer. I wouldn't try to measure any discrepancy, but use the behaviour of the saw cut to determine the alignment issue. Picture what would happen if the table were lifted at the back of the blade. The wood would bind on the back of the blade when the blade is bevelled (right of the blade) . You will use shims between the table and chassis front or back to eliminate the binding.
11/6/15       #5: General 10" tablesaw alignment ...
dave
Got it, thank you. This could take some time!
11/7/15       #6: General 10" tablesaw alignment ...
dave
Fixed, had to shim the table front almost an eighth of an inch. The worst part was that every time I tightened the fasteners the alignment would change. Managed to clamp and guess on any movement during the tightening to finally get the right results. Thanks
