Solid Wood Machining
Melamine/Blade cutting issues
1/12/16
Bruce H  Member
I am having melamine cutting issues on my beam saw. (Homag CH12) The new blade/scoring combo sounds perfect but I am getting chipping on the top. What I suspect is the relationship between the raker and the triple chip tooth. My saw guy will (and has) take the blade back and re-grind it but what is said when they bring it back is "we couldn't find anything wrong" usually the second time it will cut.
I am guessing it's an employee doing the grinding who isn't as careful as the owner would be. What are the tooth grind specifications? Is the raker supposed to be shorter than the triple chip tooth? Narrower, the same width, same height? Today my old blade was noisy but cut better with less chipping than the new blade. We are changing the set again. I am not looking for another saw guy but need to tell them what the issues are and how I see that they need to be fixed. He should know the answer. I should know a little more than I do?
